howie85 said:
Nobody has an opinion on which meter? Digital or Analog? I thought with the amount of times this meter is mentioned that I could get some feedback?
I have not checked the design specs of the meters.
But based upon other testing equipment, the sensitivity of the sensor is the deciding factor on whether one meter or the other is more accurate.
Generally speaking, if their is an improvement in the sensor, it will be with the newer designed unit, typically the digital display unit.
That said, for many testing meters, the only real difference is the display sensitivity. The digital display will typically show more units (ie 19,20,21.....99,100 etc) versus the approximation display of the analog unit (ie 20,30....90,100) with subdivisions just a guess. The flip side of the great display for the digital meter is a filter to slow the speed of the display response so that the display does not flicker between a set of values.
For quick usage, analog is generally more than sufficient. For typical consumer usage, digital is generally preferred.
