Membranes provide a 'hump' in absorbtion over a specific frequency range. In the case of our products, at a slight reduction in the high frequency absorbtion range - but not enough that it can't still be used as a reflection absorber.
The center frequency of the 'hump' in this type of damped membrane arrangement is determined mostly by the rigidity of the absorbtive material damping it and the cavity behind the membrane.
In the case of a more conventional undamped membrane, the ONLY absorbtion provided is the range that the membrane covers. There is little to no HF absorbtion. It's range is determined by the mass of the membrane and the depth of the cavity behind. In this type of absorber, it is critical to have an air-tight seal or performance efficiency will suffer.
Bryan
