I used this method recently in a modification job to a commercial speaker, as one step, in improving the unit for someone that wanted to radically improve the speakers. It was a 2 way speaker with a 6.5" midbass. Ascend CBM-170SE.
To make it clear what you see in the photos: I have cut the rear off of the speaker cabinet. I have installed 1/8" thick of Dynamat type visco-elastic material on the MDF. I have adhered 1/2" HardiBacker concrete to the aluminum side of the visco-elastic material. I have adhered oak pieces to the corners of the cabinet, and an oak runner across the center of the baffle between midbass and tweeter. I have adhered steel angle to the oak also, to re-enforce it further. I adhered the same L angle to the walls and used steel tubing, using metal to metal epoxy for the steel tube to L angle adhesion points. To adhere the steel to concrete, the best adhesive I found was PHL premium polyurethane construction adhesive. Super adhesive - far superior to liquid nails, gorilla glue, etc.. for this purpose.
New back.
If you are interested in just how much attenuation this produced. Here is a graph of accelerometer readings before and after, center side wall, same SPL:
-Chris
