Meaning of "Q" in Denon 3805 EQ measurements
pbarach1
After running the Auto EQ procedure on the Denon 3805 receiver, the results can be displayed as a series of 8 equalization adjustments per speaker. These results are in 3 columns, Freq, Q, and Gain. Can someone please explain what "Q" means here, and what difference it makes when the Q is determined to be 0.1, 0.5, or 0.9??
Thanks for the explanation!
Q, normally called Q(ts), is the resonance curve for a speaker. I'm not sure exactly what it means on your receiver, but those figures are usually associated with the way a driver will react and what type of enclosure would be used for it:
As a general guideline, Qts of 0.4 or below indicates a transducer well suited to a vented enclosure. Qts between 0.4 and 0.7 indicates suitability for a sealed enclosure. Qts of 0.7 or above indicates suitability for free-air or infinite baffle applications.
My guess is that the Q function on the receiver is the type of curve it applies to the EQ function.
WmAx
WmAx
Q, as you are referring to, is the relative bandwidth of that filter. For detailed information, please refer to:
http://www.bcae1.com/equalizr.htm
-Chris
pbarach1
Now I get "Q"
Thanks for posting that link; the graphs make it crystal-clear!
Swerd
Swerd
Q is a feature of a filter (either electrical or mechanical) that determines the shape of the filter's response around the frequency where a filter transition is taking place. Different Q values make for different shapes in the slope of a filter. Because the different filters will sound different, Q is a convenient way to identify the different shapes.
The attached picture shows the several different frequency response curves of high-pass filters with differing Q values. In this case they are mechanical filters created by different cabinet volumes and alignments for a subwoofer. When Q is low, the slope is more gradual but ultimately extends lower in frequency the the higher Q slopes. As Q gets larger, the slope is steeper and a hump appears above the 0 dB horizontal line for Q > 0.7.
Yep. That's how my sub was designed. The "normal" alignment uses a higher Q tuning, but this alignment is tuned to give better extension and smoothness at the expense of some output (and since there is plenty of output, that isn't a problem :D ).
