Match receiver (Pioneer vsk 1121 K) to speakers (JBL L series)
ananth.gutta
I have read through a lot of posts here but I still find it hard to interpret the details and match it with my setup.
I have a pioneer vsk 1121 K. It's rated as below
-Channels 7.1
-Power Output Per Channel(20Hz-20kHz,.08%THD@8ohm) 110
-Power Output Per Channel (1kHz@8ohm) 120
-Power Output Per Channel (1kHz@6ohm) 125
I am planning a 7.1 setup with speakers below
JBL L890 (fronts)
JBL L830 (sides R/L)
JBL L820 (rear R/L)
JBL LC2 (center)
JBL ES250PW (subwoofer)
My concern is with L890. They are rated at 8ohm and 125 continuous. The receiver says 8ohm and 120.
Am I okay to go with L890 or should I go with L880 that are at 8ohm and 100 continuous.
Please advise. This is my first HT setup.
Other details :
Room size is 29x15x9(height). The front speakers will have their back against the 29' wall. I cannot put them agains on the 15' walls. No windows. No curtains. The room is not completely empty. It has a 135" fixed screen, wet bar, cabinets, seating etc.
No, they don't say 125W continuous, that is MAX. With that kind of power, you would be deaf very soon in a typical setup. Very few speakers need 125w continuous. That is a fairly large room, but I think that receiver will be adequate as long as you aren't looking for concert levels.
ananth.gutta
Thanks for your reply. The specs on L890 are mentioned as below
•Power handling (Continuous/Peak) 125W/500W
•Nominal Impedance 8 Ohms
•Sensitivity (2.83V/1m) 91dB
•Frequency response (±3dB) 28Hz - 40kHz
•crossover Frequencies 700Hz, 5kHz, 20kHz
Then I should read this number - 125 as max continuous. I just don't seem to find enough discussions or reviews on JBL L series. The ones that are there are from 2007/2008/2009. Don't see much talk about them after these years... I wonder why.
The wattage rating on a speaker is all but irrelevant. It tells you very little, because in practice, you will be unlikely to use that kind of power on them. Those numbers are levels at which something in the speaker will fail (x-over or driver). Yes, it does appear they are giving a continuous rating, but I'd still question its relevance.
What I was getting at is, in a typical setup you will only use maybe 5-10 watts to achieve average sound levels. During peaks you may see somewhere in the range of 100 or more watts of demand for a few seconds, so it won't be an issue for a decent receiver, however there are other significant factors as well such as how loud you intend to listen and how big your room is and your room is medium to large.
The S series were some of the best JBLs out there, but yes, they have not been as popular of late. I honestly have not listened to the L series, but the S series were quite good. I would say that the setup you propose sounds fine, though I'd say a comparable setup of the Infinity Primus line might do just as well. Have you already listened to the JBLs?
ananth.gutta
I have not listened to infinity speakers.I have listened to klipsch, polk audio,emitova & jbl. Price and sound wise I liked JBL L series. I have listened to this combo in a proper 7.1 HT setup.
L880 (R/L)
L820 (4,all surround )
LC1
L8400
Others speakers were placed next to each other for side by side compare but not in a surround sound setup. I dont intend to listen anything above normal, but need clean sound.
Sounds like you've done the right thing by listening first, so I'd say if you enjoyed the JBLs, then that's what you should go with.
ananth.gutta
I wish I has a chance to listen to KEF. Their floor standing speakers (q500's and iQ90) seem to be in the same price range at JBL 890.
KEF is almost a no brainier. I've been a fan of their stuff for a long time.
