Martin Logan just came out with new Motion series speakers. The Motion XT.
Three New MartinLogan Speakers
The Motion 60XT, Motion 50XT, and the Motion 35XT
Motion 60XT:
Sensitivity; 94 dB/2.83 volts/meter
Nominal Impedance; 4 Ohms. Compatible with 4, 6 or 8 ohm rated amplifiers.
Crossover Frequency | 400 & 2,200 Hz | | |
Crossover Components
| Custom air core coil and low DCR steel laminate inductors. Polypropylene film capacitors in series and low DF electrolytic capacitors in parallel. Tweeter thermal/current protection. | | |
High Frequency Transducer
| 1.25" × 2.4" (3.2cm × 6.1cm) Folded Motion XT Transducer with 4.5" x 2.75" (11.4cm × 7cm) diaphragm | | |
Mid Frequency Driver
| 6.5” (16.5cm) aluminum cone with cast polymer basket. Sealed chamber format. Rigid structured dust cap to reduce cone break-up modes. | | |
Low Frequency Driver
| Two 8” (20.3cm) aluminum cone with cast aluminum basket. Non-resonant asymmetrical chamber format. Rigid structured dust cap to reduce cone break-up modes. | | |
Binding Posts
| Custom 5-way bi-wire tool-less binding posts | | |
