I've said it several times and I still insist... With the arrival of new audio formats like Auro 3D and Atmos, in-wall and in-ceiling speakers are getting a lot of attention lately. If you are one of those in search for some good speakers, let me tell you about one that really got my attention. The Edge in-wall/in-ceiling speaker belongs to the Stealth Architectural Series from Martin Logan. It has lots of potential and interesting characteristics making it a very good choice for almost every application.
By now you may be wondering what makes this speaker worthy of attention and consideration? I could write a very long article in order to explain it but, instead of doing that, I decided to make a list. Be sure to check them out and let us know what you think!
FEATURES:
- This speaker utilizes Martin Logan's larger, low distortion Folded Motion™ XTtweeter which is rotatable allowing complete flexibility for both horizontal or vertical installation.
- High-excursion bass and mid-range drivers.
- Key to their sophisticated sound is an advanced topology Vojtko™ crossover network. Each crossover is built on top of double-layered, super-thick, black PC boards and constructed with the highest-quality components.
- Internals including massive air-core coils, thick, high-purity 16-gauge copper wire, low-distortion polypropylene capacitors, low-DF electrolytic capacitors and custom wound inductors.
- Thermal and current protection.
- Premium wire connections.
- Gloss piano-black speaker baffle that hides all mounting hardware.
- Solid one-piece cast aluminum chassis and bezel-less magnetic grille.
- Disappears visually into the room, and each one has a completely bezel-less, low-profile, paintable grille for the ultimate stealth installation.
- A magnetic system secures grilles easily into place, reducing the risk of warping or damage during installation.
- The driver complements are held securely in place by a flush mounted 3/4-inch solid, high-gloss piano black baffle that hides all mounting hardware.
Price: $1,699.00/each.
Click on the photos for a closer look and product specifications and tell us what you think!
