when i pulled the subwoofer cable from the back of the AVR it made a pop sound and the subwoofer was no longer in standby. I have tried reconfiguring the subwoofer (and all speakers) several time but still no sound from sub (the AVR - marantz SR5010 sends test tones to each channel)...
This suggests that something, somewhere in the chain, is preventing a strong enough signal from reaching the Sub.
There are a lot of variables.
Too low a signal from the AVR.
too low a signal through the wireless transmitter
A problem with the Sub
A problem with the LFE channel
Those are my quick off-the cuff thoughts.
First, if you pulled the cable while things were powered... DON'T! This is a good way to blow something. Of course, it could have been a happy accident.
Easiest to check is: What is your AVR Sub Trim set at? (Suggested above.
(What happens if you turn up the Sub Trim in the AVR, does that more powerful signal wake up the Sub? You may need to adjust the Sub Gain down.)
