Connecting a turntable to a Marantz SR5007. Do you need a pre amp or can I connect directly?
G Grant Sims Audiophyte Jun 24, 2016 #1 Connecting a turntable to a Marantz SR5007. Do you need a pre amp or can I connect directly?
P PENG Audioholic Slumlord Jun 24, 2016 #2 Grant Sims said: Connecting a turntable to a Marantz SR5007. Do you need a pre amp or can I connect directly? Click to expand... You need some sort of phono preamp with the proper sensitivity/output and equalization for the specific cartridge types.. http://www.project-audio.com/main.php?prod=phonobox
rojo Audioholic Samurai Jun 24, 2016 #3 Yeah, looks like the SR60xx model line has a phono input, but the SR50xx line doesn't. You appear to need a preamp to boost the signal before connecting it to your AVR.
