Manual Eq Setup Settings - Denon 3805
  • Thread starter Thread starter avliner
avliner
avliner
897
0
43
Buckeyefan where are you??
Hi,
I was just wondering whether I'm doing the right thing in tweaking the Manual EQ Setup Settings on my Denon 3805, so my question is:
should I select the MANUAL OPTION (at Manual EQ Setup window) BEFORE start tweaking (boosting and/or cutting freq's)?
Or should I leave it at the pre-selected option (flat is the best for me) and only then run the adjustments?
Matter of fact, I couldn't find any info about that (manual, AH review & threads). Just want to be sure, because I hear a tremendous difference in sound between MANUAL & FLAT (far better), after tweaking with the freq's.
Believe it isn't a big issue, as your ears will decide at the end, but just to know what the right procedure is.
Cheers / Avliner
