MakeMKV Beta with HD audio works with backed up bluray movies!!
duggyhow
What up, for anyone who wants to make a backup of their bluray movies and play them thru MPC-HC, MakeMKV Beta works with HD audio incluced!! It is also free. Twister is the only movie I have had a problem with. It cuts out for some reason. Has anyone else run across this?? The audio is choppy on this movie for some reason. I've tried different renderers but the same problem. I wonder what to do. Thanks.
BoredSysAdmin
BoredSysAdmin
Make sure to use latest catalyst drivers and get newest SVN of MPC-HC,
Also double check your video renderer is set to EVR or EVR advanced and you should be using internal mpc-hc decoder to utilize your gpu. CoreAVC codec can't.
