Mac mini to integrated amp question
ematthews
ematthews
I have been running my computer as follows and want to know if this is OK.
I think it sounds fine.
Computer out through the headphone jack into a rca splitter that hooks into the Video/aux in. I just put it on video when I run the Itunes through my system.
Is this OK or am I missing out on something
I see a lot of write up on Computer to DAC to Stereo..
Is this the correct way to run it? I don't own a external DAC so I was wondering if I should get one since most of the time I listen to music from You Tube, Pandora and Itunes through my system speakers
JohnA
JohnA
The mini has an optical output doesn't it? That would be better.
ematthews
ematthews
I don't think mine does. Maybe. It's about three years old. In any case My Stereo does not have optical in.. Unless this is what the external DAC would link between for
JohnA
JohnA
What version mini is it? Also what receiver do you have?
dkane360
dkane360
So if your receiver doesn't have optical in, you wouldn't be able to use this.
My receiver is a Marantz PM6004
Correct, although you can use a DAC if you want to take advantage of the optical out.
