M&K Speakers question/advice
malcho
Hi,
I am looking for a suitable center channel for my system. I have the proffesional M&K MPS-1610 as my left and right and I am looking for a center channel from M&K which will match them best. Any recommendations? What is the way to determine if the center channel will be a good fit? Is it all about the tweeter?
Thanks
N
Khellandros66
Khellandros66
More info would prolly help..
Such as;
Receiver/Prepro/amp
Display is it a plasma thats wallmounted, or a front projection system witha micro perf screen..
Info like this would help us help you.
~Bob
Sheep
Sheep
Try the MP-150 (First one on product page in "The plasma series")
No doubts is a good speaker. Whether or not its in your price range is another story.
SheepStar
malcho said:
Hi,
Thanks
N
If you can place another one of those 1610 in the center, that would be ideal, of course. If not, check out what sheep suggested.
malcho
I have Acurus A200x3 driving the fronts for now. I have a CRT TV wich I will change at some point to a plasma or a DLP. Currently I have a LCR55 MKII as my center, but would like something bigger for more dynamic range. I know the best would be another 1610, but they are discontinued. I was wondering if I can use the S-125 center or the LCR750 or LCR851 centers. Thoughts?
Thanks
N
Sheep
Sheep
All those choices look good. What do your M&K's look like right now? LCR, square box? If its the LCR design, I would grab any of your choices. Make sure you listen first though. They might not have the same timber.
SheepStar
