M&K speaker costs$$$$$ !
RJC
M&K speakers seem very expensive! Are they worth it? For example, in Canada k-5s are $700.00/pr, K-17 $1000.00/pr, K-4s $800.00/pr, KX-10 sub $1000.00 plus 15% tax here....WOW!
jaxvon
jaxvon
It really depends on what you value. They are very high quality speakers and are used in many, many recording studios due to their accuracy. Is it overkill for you? Perhaps. If you've auditioned the M&K speakers and love them more than anything else you've heard, then it's probably worth the cash. However, if you find another speaker for less money that you like better, then it's a better deal. Just because M&K is supposed to be "better" doesn't mean that you'll like it more. As speakers (and room acoustics) are the main players in the sound of your system, speakers are highly subjective and personal choices. I would recommend that you check out M&K and compare them to other speakers. You might just find something you like better for less money.
happy540i
Hello there! You are right, M&K's are expensive. I have two systems at home, one Yamaha and the other one is Denon. They are both connected to M&K speakers. The Yamaha is connected to consumer series speakers and the Denon is connected to Professional series speakers. Both system sounds excellent. It is a good choice and not a bad investment. It comes with a 10 yr. warranty. Also you might want to consider going to M&K's website and buy refurbished items. Sometimes you can get it at half off. Good luck.
