Hi, guys. I have a pair of Edifier S2000 pro active speakers hooked up with 2 sources: 1) To a Panasonic VT60 via optical cable and 2) to my samsung galaxy s9+ phone via bluetooth. I've always noticed that at full volume on the speakers, sound is always much higher using my phone as source rather than the TV.
I am not sure which of the two sources is doing the correct thing in terms of audio signal output, but I definitely prefer the loudness of using the phone. My problem is now am connecting a Bluetooth transmitter between the TV and speakers and said transmitter can work both as transmitter and in bypass mode. In TX mode I am listening to the TV's signal on a new pair of Sennheiser Momentum 3's via bluetooth and in bypass I can listen to the TV's signal on my Edifiers.
Bypass sounds identical as the original configuration, but now the low volume is quite noticeable on my headphones. Again, if I connect my phone directly to my new headphones via bluetooth, they sound louder than when connected to the bluetooth transmitter listening to the TV's output.
My TV is connected to a number of A/V sources including an HTPC, a PS4, Switch, and finally a Chromecast (which I sometimes use to stream Spotify).
I guess finally my question would be, with my current setup, what could I do to increase overall sound quality and loudness? I was initially thinking about just getting a good quality A/V receiver, but then read that it wouldn't work with my active speakers.
