see pages 41, 51 and page 70 of your manual
Hello everybody,
Let me preface my question by saying i'm new to this. I recently bought an onkyo 605 and cerwin vega 5.1 surround sound speakers (my first time buying either a receiver or speakers). Ran audyssey but it doesn't detect the subwoofer. The speakers emit plenty of sound during the test but the subwoofer outputs very little. You can barely hear it. Did some research and found that the speakers need to be set to "small" but i cannot find any configuration in the menu to make such a change. In the speaker configuration i have the speakers set to 80HZ, subwoofer "yes", LPF 120HZ. Also set the LPF to 150Hz on the back of the subwoofer. What the hell am I doing wrong.
from page 41
Audyssey 2EQ function can measure the number of
speakers connected,
their sizes, crossover frequencies,
and the distance from each speaker to the listening position
and calculate the optimal speaker settings for your
listening environment automatically.
from page 51
less than 6, set the minimum speaker impedance to 4
ohms (not North American models).
If you’ve connected your front speakers to the FRONT
and SURR BACK terminal posts for bi-amping, you
must change the Speaker Type setting. For hookup information,
see “Bi-amping the Front Speakers” on page 21.
from page 70
Speaker Settings
If you change these settings, you must run the automatic
speaker setup again (see page 41).
If the impedance of any speaker is 4 ohms or more but
Notes:
• When bi-amping is used, the AV receiver/AV amplifier
is able to drive up to 5.1 speakers in the main
room.
• Before you change these settings, turn down the volume
