Low Frequency Question..pg 52 on RX-V2400
jzac
I was trying to match my new Axiom EP-600 with my existing front M80 speakers using the LOW FREQUENCY test, and in the RX-V2400 receiver manual on page 52 I have the following bullet...
4. Adjust the volume of subwoofer with the controls on the subwoofer so it matches that of the speaker you are comparing it to.
The initial setting by the receiver is 88Hz and it stays that way even after going through the YPAO setting. :confused: Question is how do we double check that this initial setting is the best for me? I have an SPL meter with me too. The range is 35 to 250Hz. What should I be looking or listening for that "matching" Hz? Can someone enlighten me...pretty please? :)
Thanks!
W
warpdrive
If you ran the YPAO, the receiver has set the correct level for you. You don't have to do anything else. What you are trying to do is adjust the levels MANUALLY, but if you ran the full YPAO, the receiver has already set the correct sub levels for you. You don't have to do anything else!
You are looking at the LFE test menu....But if you wanted to set the levels manually, you can use the LFE test menu. That 88Hz value is the frequency of the test tone which is emitted when you select the Test Tone "On" menu item. Then you can use the arrow keys to change the frequency of the test tone from 88Hz to some other frequency while observing the levels on your SPL meter. The trick to using it is to pick two frequencies, one where the subowoofer is active and one where your mains are playing. Then compare the levels while looking at your sound meter. So if your crossover is set to 80Hz, play the tone at 50Hz, and play the tone at 110Hz and compare the levels.
But again, you don't need to do this.
jzac
Thanks for the tip Warpdrive. I figured I wouldn't, but wanted to confirm. Reading too much can be pretty painful too! :D
