Humberto
Hi There!
I'm connecting wires of the same type in my surround and center speakers, which is not happening to my front ones (wire's diameter is different).
Am I loosing quality?
Regards.
[Edit: Please don't double-post. Providing additional info will help you net some better responses. - Admin.]
Humberto said:
Hi There!
Regards.
Are those front ones long cables? how much smaller are they or what is the wire gauge? Most likely it will not matter.
Humberto
Thanks again
mtrycrafts,
In fact the surround and center wires are 2 x 1.25mm2, while the front ones are shorter and are 2 x 1.50mm2.
That means I won't have any problem, correct?
Regards.
jcPanny
jcPanny
Not sure about the conversion, but 14 AWG or 12 AWG wire will work fine for your fronts, center, and surrounds.
