sgtbyls said:
I hear the noise when i turn on the amp first, then the tv. I guess im just trying to find out if its a somewhat normal thing, or if i have done something wrong.
The amp is trying to amplify anything present. aka Noise floor, or just a spurious signal from the TV.
In this case, there is a small signal (garbage signal) from the TV upon startup. Most likely the noise is from the switching system for the TV, or the startup juice needed for the TV display. Remember, most TV's, especially big CRT's, have a pretty significant initial power consumption, so some noise is possible.
Is it normal. Normal would not be the word that I would use, but it is common.
Is it desirable. No.
To avoid the problem, sequence your equipment so that the TV comes on first.
My separates recommended a specific sequence of preamp, CD, amp etc to avoid similar problems.
