<font color='#000000'>Hi, I've recently purchased a new receiver (Sony STR DE595) and set of 5.1 speakers (Omni 898 - probably not much good from an audiophile point of view, but they were relatively inexpensive). I have the satellite speakers connected to the receiver and the subwoofer out from the receiver goes into the sub-in on the subwoofer (which is one of those with built-in amplifier and 5.1 analogue input with speaker outs to the satellites). I don't use the other 5 channels of line inputs on the subwoofer (I just need it as a subwoofer).
The receiver is connected to the TV, VCR and DVD units. All connections are with standard (I assume) RCA cables.
The problem is, the subwoofer exhibits a loud, annoying buzz & hum, which seems to be very dependent on where the RCA input cable is positioned. If the cable isn't plugged in at all, the loud buzz is gone, but I can still here a faint buzz/hum coming from the subwoofer with the power on (when on standby, there is no buzz).
If I disconnect the cable from the receiver but still connected to the subwoofer, I still get a fairly loud buzz (also dependent on position). With the cable connected at both ends, if I grip the cable with my hands, then the buzz decreases to acceptable (for me) levels.
If the cable is connected to the receiver and subwoofer, the buzz decreases to acceptable levels when I place my hand over the unused RCA inputs on the back of the subwoofer unit. Covering one RCA input with my hand lessens the buzz somewhat, and covering more decreases the buzz even further.
The subwoofer also faintly picks up radio signals.
I don't have any of these problems with either the satellite speakers or the 2 speakers I was using before (either that, or it was less noticeable).
All my gear is connected to the same power socket, and they all have the 2-prong power plugs except for the subwoofer unit and an indoor TV signal gain amplifier antenna (we get shoddy TV reception in this apartment with all the high rises around - the outdoor antenna plugs into the indoor antenna and passes through to the TV), which both have 3-prong plugs.
From reading various sites, I'm getting the impression that I have a grounding problem (and a Radio transmitter that's too close to my area). These sites talk about balanced vs unbalanced inputs and outputs, but I'm still not sure what I can do to fix the problem given the various symptoms I described above.
Would a better shielded subwoofer RCA cable help (as opposed to a standard RCA cable)? Do I need a ground isolator or similar accessory (which is probably not going to be cheap)? Is my subwoofer defective?
Any help greatly appreciated! Thanks.</font>
