Hey guys, ok first of all let me list my current setup, so you know what you're working with here....
- Samsung LE40R7 (108i) LCD
- Rotel RA-01 Integrated Amplifier
- NAD C521BEE CD Player
-Tannoy Mercury F4 Floorstanders
Now, I'm going to be purchasing a Panasonic DMP-BD35 at some point within the next few months as my entry into Blu-Ray.
I'd like to make my system 5.1 before I do this, now, I have a pair of speakers spare (my old speakers), they're Monitor Audio Bronze B2's, would they work ok for the rear?
If so this leaves me missing a centre speaker and a sub, now the centre speaker is easy, as I can buy the speaker that matches my floorstanders for cheap nearby, this leaves me requiring a sub, I only have a small budget but had my eyes on a Wharfedale Diamond SW150 (which I have found a very good price on, £180 delivered), now, my current amplifier (Rotel RA-01) has no sub-out connection, I've read things about Y-splitters etc but it started giving me a headache, so I thought you guys could maybe clear things up for me?
So as I've said I'm planning to buy a Blu Ray player, a sub, and my other purchase was going to be a new amplifier, but because I found a very good price on the sub I listed above(and they only have 1 left in stock so I want to snap it up), then my amplifier purchase will probably be after the sub (hence my last question to see if it would work with my current amp), the amp will be for a 5.1 setup, mostly music and some 5.1 Blu-Ray film playing! My price bracket is around £200-250, can I get a decent upgrade for that limited budget? I saw that I could get a Rotel RA-04, not sure how much better that is to my RA-01 but it did get some solid reviews....
And lastly is a little side question, I have my 360 playing through my current setup, yet when my system is on with the 360, sometimes I get a little speaker pop every now and then (this doesn't happen when I'm running music, only when I run the audio from the 360, it's not the end of the world but it does irritate me and I'd like to get to the bottom of it!
Sorry for the huge post guys, and thanks in advance
