I have a Marantz SR6006 and an Oppo BDP-103 in my upstairs system. Both are roughly 4 years old.
Recently, when I played a Blu Ray the sound had almost no voice content (it switched on and off). The non-human sounds seemed to be close to normal. I suspect I'm losing the center channel but I have not actually checked this.
Blu Rays always played back with no problems previously, and the sound is fine when watching TV from the satellite signal. It's only when I play Blu Rays.
The Marantz seems to make some "switching" noises during playback (the same noise it makes when it is turned on) randomly, and the sound (voices) comes on and off randomly (mostly off, unfortunately)
My downstairs system also has a Marantz SR6006 and an Oppo BDP-103. When I pop the same Blu Ray into the downstairs system it plays back fine.
Any ideas? Is there a setting in one of the components that could be causing this? I'm planning to switch over to a 4K system in the not-to-distant future, so I'm thinking about just replacing the SR6006 unless there's a simple fix.
