Looking wall mount suggestion.
bellevegasj
I need a mount for my 46" lcd. I need to be able to swivel it from left to right and tilt it as well. Any suggestions?
Thanks,
J.
BMXTRIX
BMXTRIX
It also depends on the TV you have! There are tons of 46" LCD displays on the market, and picking one which is rated to support the weight of your display is critical.
Almost every major manufacturer has a nice 'mount finder' right on their front page for projector mounts.
http://www.peerlessmounts.com
http://www.chiefmfg.com
http://www.premiermounts.com
http://www.omnimount.com
Even then, there are far lesser expensive univeral options like this one from Monoprice for under $50!
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082806&p_id=4562&seq=1&format=2
From this category...
http://www.monoprice.com/products/subdepartment.asp?c_id=108&cp_id=10828
So, doing some research and homework and matching a mount to your display may be really important, or not as important depending on your budget.
