Looking to use my computer speakers for a PS3.
dalevm87
Hi after intensive google searching and lots of confusing forum questions I found this site. Basically I want to play games on my PS3 and have the sound coming through my PC speakers. The speakers are Logitech Z623 and are connected to the back of my PC. My sound card is through ASUS, I can't find the model# at the moment but its Realtek High Definition Audio if that helps any. PS3 is connected to my TV via HDMI is there any way I can leave the speaker connected to my PC and have them play sound when I am using the PS3? I have an optical cable hooked up from the PS3 to the PC if that helps any. I cannot figure out the right configuration or if I'm just missing anything. Any help would be greatly appreciated thank you.
BoredSysAdmin
BoredSysAdmin
you should able to connect your PS3 optical audio out directly to speakers and use your PC's audio card to connect to speakers with analog connection.
