Looking to upgrade from my integra
ddjr
I recently gave my son my integra receiver and am looking for a replacement. It will be powering a pair of kestrel hot rods, as well as an old pair of newly foamed Allison sevens. I'd like something with Bluetooth, but really, great sound is what I want. I'm not opposed to older equipment, as long as I'm not moving down from the integra. If you guys have any suggestions, I'd be grateful, as I don't have any stores where I could see them in person.
What model Integra did you have? This is for a 4.0 surround setup or are you using two pairs of speakers in 2ch like A+B? Budget?
ddjr
I believe it was a Dtr 6.4
Yes, a and b (2 channels)
My budget... Has taken a hit, so I'd say no more than $800. Thanks for the reply
Do you run the two pair simultaneously? I saw some spec on the Allisons, they are 4 ohm speakers in the low range particularly, didn't see any on the (Meadowlark) Kestrel Hot Rods.
ddjr
I don't have to use both pair, one pair is plenty. I've been looking at an anthem. Seems ok.
Anthem what? Brand alone isn't very meaningful. Are you looking new or used?
ddjr
Anthem mrx 700. I'd consider new or used, as long as I don't end up with a lesser quality than my integra was
How are you defining the "quality"? The Onkyo/Integra unit had decent spec but nothing particularly unusual. The MRX700 isn't a 2ch unit either (altho could work just fine) and seems $800 seems too high of a price for a 10 year old unit (if it is $800). Does have a decent feature set, tho. What features/connectivity do you need for your various sources?
ddjr
I really am only concerned with the sound. Bells and whistles aren't as important to me as the great sound my integra put out.
There are many units that can do that. You're going to have to narrow it down some. What gear/content will you use it with other than the speakers?
ddjr
I may run my old California audio labs cd player through it. Radio tuner. I suppose it would be nice to Bluetooth Sirius radio or YouTube through it. But that's not a necessity for me, as I usually use headphones for that.
