Looking to change my amp, need help?
Darrenmc
Right now I have an Esoteric AI-10 integrated amp. It is 110 watts into 8 ohms and 150 into 4 ohms. Decent power. The problem is it has no pre outs an leaves me no options down the road to add more power or use a sub. I'm good with my source, a Bryston BCD-1 and my speakers, PMC OB1i's. I have been looking at the Krell 300i, it has more power and pre outs. It is half the price of the Esoteric though, so is the build quality inferior? I do like the idea of a having one box because of space constraints but I am also looking at separates that are small such as the Wyred 4 sound STP-SE preamp and SX500/SX1000 mono's. Also there is the Wyred 4 Sound STI-1000 integrated amp as well. One other option is the Peachtree Audio Grand integrated. Any thoughts would be appreciated. Feel free to offer other suggestions as well. Thanks in advance.
ski2xblack
ski2xblack
Wow, you like the expensive stuff. Quick sarcastic answer: just get an HK3940 and spend the rest on music! ;)
If build quality is a big concern (and in the price range the items you mention had better be bomb-proof for the cost!), consider a Bryston integrated. They all have pre-out/main-in capability, would cosmetically match your source component, and of course there's the warranty thing (transferrable on used gear, too, I believe).
walter duque
walter duque
You might want to check this ia01_integrated out. I have owned a few of their power amps over the years. Top notch amps.
