looking to buy a new pioneer vsx-1123
W
warren g
hello, i need some info on the pioneer vsx-1123 and the onkyo txnr626. i am trying to find out which is the better receiver for my needs.like which one has the best sound output and best speaker setting. i have the bose acoustimass 10 speaker system. i like to know which av would give me the best sound for my money.
Adam
Adam
Welcome to the forum, Warren!
You might like to check out my review of the Onkyo TX-NR626 that I posted on this forum, linked here. It might be a good starting point to help you consider what your "needs" are, and what might best serve them. They might both fit your needs, or perhaps neither will. Power-wise, they are very similar.
The biggest difference that I can recall between those two receivers is the auto calibration systems. Pioneer uses MCACC, and Onkyo uses Audyssey. For a single listening position, I'd call them a wash. If you have multiple distinct listening positions (like I do), then MCACC is the better choice because it can store up to six different configurations, whereas Audyssey can only store one.
