Well, here goes. As the title states i'm looking for a nice 2 channel setup. This system is going to be for listening to the radio. What I would like help with is figuring out what pieces i need. I think i would like a system of separates, tuner, amp, pre amp. or tuner and integrated amp. But Im not sure i need all of the features these offer, as this will only be used to listen to radio. I believe a system of separates would sound the best. My thinking being that if i buy a NAD C427 for say, the radio would sound better than off a Yamaha HTR-5940 where the radio is likely just there as another feature.
The only piece of the puzzle that is already in place are the speakers, which are ordered already. They are a pair of Fluance SX6 Bookshelf speakers. Here are the specs.
SYSTEM TYPE 2 Way - 2 Driver Bookshelf Loudspeakers
TWEETER 1 inch Neodymium Balanced Silk Dome Ferrofluid Cooled
WOOFER 5 inch Polymer Treated Driver with Butyl Rubber Surround
POWER HANDLING 30 - 100 Watts
FREQUENCY RESPONSE 50Hz - 20KHz
SENSITIVITY 92dB
CROSSOVER FREQUENCY 3500Hz PCB Phase Coherent - Mounted Circuitry Butterworth Design
IMPEDANCE 8 Ohms
ENCLOSURE Tuned Rear Port Bass Reflex Bookshelf Design
DIMENSIONS (H X W X D) 13.5 x 8.3 x 9.1 inch
WEIGHT 11.6 pounds/speaker.
These are not million dollar speakers, but i believe they will sound great when paired a compatible system. I would like help figuring out how to match these with an amp. I'm not sure how many watts per channel would be necessary in order to make good sound. I would like a warm sound, and i am open to all suggestions. Thanks in advance for any and all ideas.
