Looking for system help around $5K
ryandaws
Hi all,
I’m looking to put together a new system, and after reading through forums, websites, etc. I am still pretty lost on some fundamental questions. For example, why haven’t I seen a single negative review of a speaker? How much of my budget should be allocated to speakers v. amp(s) (I’ve heard everything from 50%-80%)? Should I be considering bookshelf or floorstanding speakers? What share of the budget should be allocated to Mains v. Center v. Surrounds v. Sub, and should they be the same brand?
I’d like some expert opinions on the above questions, as well as some suggestions on what my system should look like. A few key points of guidance:
  • My max budget is ~$5K for everything
  • I live in an apartment, so the system will generally be listened to at neighborly volumes; needs to sound great at lower volumes
  • I would like the system to be multichannel for TV and movies, but the primary use will be for 2-channel music (so unless there’s something amazing about multichannel music I’ve never experienced, I’m considering being super-thrifty on the surround speakers because the creaking doors in movies aren’t interesting enough to spend a lot of money on, or maybe even using the Beta 50s as the surrounds)
  • I listen to rock, classical, little bit of pop, little bit of metal
  • I ‘ve had HK 3480 stereo receiver, two Infinity Beta 50 floorstanders, and an Infinity SW-12 sub (speaker review here (tinyurl.com/3fnludt) for years now and need a system that’s sufficiently better to justify the upgrade. I will probably keep that sub, but the floorstanders should probably go. Advice appreciated on that front.
  • My exclusive source for music will be digital files; depending on the pre/pro or receiver, I may need a Squeezebox, but I do not need any other source (I don’t have any CDs or Vinyl anymore)
  • System will be in the living room of my apartment, which is probably 15x20x8.
Based on what I’ve read, I’m thinking this so far:
  • Emotiva UMC-1 7.1 Pre/Pro ($700) (is it worth going to the Marantz AV7005 for twice the money or is it better spent on speakers?)
  • Emotiva XPA-5 5-channel power amplifier ($900)
  • Keep the subwoofer
  • Center channel, mains, and surrounds: Totally lost. Probably $2K for the mains, 500 for the center, $300-400 total for the surrounds? Suggestions very much appreciated.
I know this has been an unholy mess of a bunch of n00bish questions, but really appreciate any help you can give me!
zieglj01
zieglj01
Hi all,
neighborly volumes;
It is up to you, if you want to spend $5,000
For me and is subjective - If in an apartment, I would start with a good receiver with pre-outs,
get a good sub and worry about amps later. My suggested ratio, 1/3 receiver and 2/3 sound
For speakers - look at the Focal 816 towers and 800 center. You can use Infinity for surrounds.
http://spearitsound.com/focal/focal_800_series.htm
This is an option for budget surrounds - I am more 2 channel or 3 channel on music.
http://www.musicdirect.com/p-4905-focal-sib-black-compact-speaker-pr.aspx
Epik subwoofer - you can turn the volume down
http://epiksubwoofers.com/legend.html
BoredSysAdmin
BoredSysAdmin
To outperform your Infinities, I would look into these:
Salk SongTower (pair) 1899
Salk SongCenter (one) 795
NHT SuperZero 2.0 (pair) 198
Total = 2892 + shipping
or, for less cost
Salk SongBird (pair) 1299
Total = 2292 + shipping
I agree with zieglj01 about getting a decent AV receiver that has pre-amp out put jacks for at least the main left & right speakers.
I'd +1 Swerd Rec for speakers, and I'm personally drooling over upcoming Onkyo TX-NR809.... Just saying...
One more thing to notice, unlike SongBird, SongTower are rated 4 to 6 ohm Impedance - Not every receiver can handle these loads
slerch666
You haven't been looking in the right places? Seriously though, it depends on where you look. So if you're looking at Amazon reviews, you have to remember most of those reviews are from people who actually bought the speakers. You don't think they want to dump on something they've paid money for, do you? "Professional" reviewers get the gear for "free" so they are more likely to be slightly more subjective about things, though I've seen some reviews where just because a loudspeaker cost $5000 it got a glowing review.
How much of my budget should be allocated to speakers v. amp(s) ?
Most of it. In theory you should be able to find the perfect speakers for yourself that can output the power you want/need and keep you satisfied for many, many years. I actually spent ~80% of my budget on speakers and am STILL spending on speakers as I wasn't satisfied with my crappy sub nor the center channel I received for free. Depending on what you're looking at, they are potentially the most expensive part of the whole mix, and if they aren't and the equipment is, most likely you're spending WAY more on equipment than your speakers even need to be driven with. Many 8 Ohm speakers are super efficient and sound great, meaning you tend to not need a whole lot more than a really good AV receiver to drive them.
Hi all, Should I be considering bookshelf or floorstanding speakers?
Yes. It really all depends on the application and how big your space is. How large/small is the room? If you are trying to fill a 15x10x8 area with sound, book shelf or floorstanders will be enough. If you plan on moving to a bigger space, try to envision how large this future space will be. If you're looking at the potential for a 20x20 space, look at bookshelves but also floorstanders. And if you're looking at bigger than that for the future, look pretty much exclusively at floorstanders for at least the fronts and potentially the rears.
Hi all, What share of the budget should be allocated to Mains v. Center v. Surrounds v. Sub, and should they be the same brand?
The front l/r, if you plan on listening to stereo music, should bear the brunt of the cost honestly. If you plan on home theater, the center is an integral part of the equation and you shouldn't necessarily skimp on that either. In all honesty, what I'm finding out as I build out my system is that the center channel should be mounted in a vertical over horizontal position, unless specifically designed to deal with the sound radiation issues horizontal orientation brings to the table. This negates a surprisingly large amount of center channel speakers, as despite being designed as horizontal speakers they are really designed for that orientation. It's difficult for me to explain. If you can get the same speaker for front, center and rear, you're golden. Most people don't do that though.
The speakers should be a timbre/sonic match for the best sound quality, which generally means limiting yourself to specific lines from a specific manufacturer. You can, however, happily mix and match and still be satisfied with the sound. If you are someone who has some level of interior design intuition, you'd probably never be satisfied with the "ugliness" of a mix and match setup. The sub can be from a different manufacturer, though some will tell you this should match the speakers as well. I'm using an Acoustech subwoofer with my B&Ws and have no problem with the sound quality of the bass when the sub is included in my music or theater playback.
It's been said before and it'll be said a million times again. Find somewhere you can actually AUDITION the speakers and potentially receiver/amps you are looking at. This can't be stressed enough. And make sure you take YOUR material with you. Bring CDs, DVDs, Blu Rays and your MP3 player and make sure it's all material you are intimately familiar with and want it to sound its best. If you don't have a Hi-Fi store in your area, Best Buys mostly all have Magnolias in them, so worst case scenario you can audition what they sell if nothing else. And if you do audition in a hi-fi shop, buy from them if they do a good job of helping you figure out what you need and what sounds best to you. It's pretty rude to audition locally then buy from Amazon or something.
Hi all,
$5000 is a good budget. I've spent ~$3500 so far and will most likely be in the $5000 range when all is said and done. My room is 25x18x10.
Looking at the Infinity Beta 50 specs, the frequency response looks good. The power rating looks good. Sensitivity looks good. Unless you are completely dissatisfied with them, you may want to just keep them. Though looking at your budget below, spending $2000 on the front l/r will net you a better sounding set of speakers for sure.
The Emotiva UMC-1 should be more than adequate for what you're trying to accomplish. One thing to be aware of is that it will NOT do 3D pass through. It's HDMI 1.3a and not 1.4 spec, so it's not able to do 3D. If you don't plan on ever doing 3D, it's probably perfect.
Then I look at the Emotiva XPA-5. First, it's $900. The second question becomes... do you really need it? The UMC-1, assuming you get 8 Ohm speakers, should easily be able to handle a 5.1 or 7.1 power load at the levels you hope to run it at. I'd only recommend upping to the better amp if are trying to really drive the speakers loud. At apartment neighbor friendly levels, there's not way you're likely to ever need an amp. The other good part about the amp is it can always be added later if you decide you need it, right? So try the UMC-1 (or whatever you decide) and see how it performs on its own. If its not able to drive the speakers at the level you want, then decide to get the amp. But from what I can see on your room size and the levels you want to drive, I really think the amp would be overkill at this point. If you plan on moving to a house and it's not a townhouse or you aren't right next to your neighbor and you want to drive them hard, then buy it when you move.
For the front l/r I'm using the B&W 683s and they are fantastic. No complaints. I love the depth and the brilliance of the sound from them. They were $750 each. If you can afford the next step above and out of the "budget" 600 B&W line, do it. I couldn't afford it so I stuck with the best in class based on personal auditions. 683 frequency response is great and even at higher levels there is no problem from them at all.
But really the best thing for you to do is to decide how much you want to spend on speakers total. Locate a local hi-fi place and really get to know the equipment you're looking at. Not sure you'll find an Emotiva receiver there, but in terms of speaker selection and finding you the best option for your budget, you can't beat a great hi-fi team helping you.
Don't let anyone tell you that what they have is the best. Experience it for yourself. Don't blind buy off the Internet. Doing either will leave you questioning whether you really got the best options at your budget. You'll get upgrade-itis and probably want to upgrade long before you actually need to.
The last thing to consider is music quality. If you have a low bit rate source, the best speakers out there will make it sound like poop. A good loudspeaker should present you with exactly what's there, and if you're focused on 128 bit MP3s, you will be sorely disappointed with good equipment. If you've got FLAC files then you should be golden, or even lossless WMA/AAC or even high bit rate compressed files.
If all your files are on a PC and you want to drive the music from the PC, you might want to look into a DLNA capable receiver. You're going to pay more than the $700 of the UMC-1, but you'll save yourself a lot of heart ache down the road going with DLNA today if that's your plan.
sholling
sholling
The first thing to pick out is speakers and then pick out a receiver to support the needs of the speakers. I agree with zieglj01 that you're unlikely to need a separate amp in an apartment. To give a solid recommendation for the subwoofer we'll need to know total room size in cubic feet - including anything any spaces open to the room. Assuming the room isn't too big the Epic Legend is probably a good choice for an apartment but I'd decouple it from the floor by putting it up on an Auralex Gramma isolation riser ($50).
I also agree with Swerd about Salk Song Towers and the Song Center. Amazing sound for the money but they are built to order so plan on a bit of a wait but they are well worth the wait. If you can swing the matching Song Surrounds that would be best but if not then a perfect match isn't critical for the surrounds unless you decide to get into 5 channel music. The Song Towers are fairly easy to drive for a 4ohm speaker and something like an Onkyo TX-NR709 ($800) or to save some money a factory re-certified 708 ($500) or 808 ($650) from Accessories For Less will drive them just fine. Both have preouts should you want add an amp later.
Swerd
Swerd
The SongTowers are apparently an easy speaker to drive, even if they go as low as 4 ohms impedance. Jim Salk says any amp or receiver that delivers an honest 50 watts/channel at 8 ohms can drive these speakers. In my experience, I've heard these speakers driven by amps from as low as 35 wpc to as high as 280 wpc. None of them were insufficient.
If the OP is interested in SongTower reviews, both from owners and professional reviewers, here is a somewhat comprehensive list:
fsimms SongTower Impressions
http://www.audiocircle.com/circles/index.php?topic=44172.0
My SongTower Impressions
http://forums.audioholics.com/forums/showthread.php?t=36600
and some working photo links:
http://api.photoshop.com/home_7e53687d13c747d28ccec9a6980c7256/adobe-px-assets/a0c5734bee194fdb9a8c51a0bb77220e
http://api.photoshop.com/home_7e53687d13c747d28ccec9a6980c7256/adobe-px-assets/763dd32e03c64e46a5d3209c017a7481
http://api.photoshop.com/home_7e53687d13c747d28ccec9a6980c7256/adobe-px-assets/1fe476c13cc44c14a769654cf21c19bd
http://api.photoshop.com/home_7e53687d13c747d28ccec9a6980c7256/adobe-px-assets/2b778c95c2ce45f6aa432373d67150a3
http://api.photoshop.com/home_7e53687d13c747d28ccec9a6980c7256/adobe-px-assets/5e32892df5334d48abd18b49b2da3c2b
http://api.photoshop.com/home_7e53687d13c747d28ccec9a6980c7256/adobe-px-assets/ba771834cf1041849f263d0eb0a728c8
Boybee's SongTower Impressions – Read the whole thread to find all 3 installments
http://www.audiocircle.com/circles/index.php?topic=49037.0
and at AudioAsylum:
http://www.audioasylum.com/reviews/Speakers/Salk-Sound/SongTower-QWT/speakers/26/265096.html
funkmonkey's SongTower Impressions (scroll down about half way)
http://www.avsforum.com/avs-vb/showpost.php?p=13285847&postcount=168
Enjoy The Music Review by Nels Ferré – Best of 2008 award
http://www.enjoythemusic.com/magazine/equipment/0408/stalk_signature_songtower.htm
Audioholics Review by Tom Andry
http://www.audioholics.com/reviews/speakers/floorstanding/salk-songtower-qwt
Also see the interesting forum discussion that followed this review
http://forums.audioholics.com/forums/showthread.php?t=47528
Audioholics 2008 Products of the Year announcement
http://www.audioholics.com/buying-guides/product-awards-and-gift-guides/audioholics-2008-product-awards
Nuance's Impressions of SongTowers with ribbon tweeters
http://forums.audioholics.com/forums/showthread.php?t=47314
and at AVS Forum
http://www.avsforum.com/avs-vb/showpost.php?p=14575239&postcount=3475
Sonic Flare Review by Sean Fowler
http://www.sonicflare.com/archives/salk-signature-sound-song-tower-review.php
Audioholics features SongTowers in Floorstanding Speaker Shootout
http://www.audioholics.com/reviews/speakers/floorstanding/1500-2000-floor-shootout-2009
Here are my thoughts:
For pre-pro/amp, I would just get a Denon 4311 or 4310:
http://www.amazon.com/Denon-AVR4310CI-7-1-Channel-Multi-Zone-Connectivity/dp/B002AKKFQC/ref=sr_1_3?ie=UTF8&s=electronics&qid=1305736667&sr=8-3
If you talk to Electronics Expo or Onecall or J&R Music World, you can get a new Denon 4311 for $1,500.
The AVR-4310 was retailed @ $2,000 a yr ago, but is now $900.
I would not get an amp just yet. You probably won't even need one. But if you do, you can always add an amp in the future. Easy solution.
And that's the easy part.
Speakers are a different story.
Most tower speakers, unless it the Def Tech BP7000SC or Revel Salon 2 or some $30K speakers, will require a subwoofer for movies anyway. So you may just get 5 large stand-mounted speakers + 1 subwoofer for a 5.1 system.
The 2 most important things about the speakers and subwoofer are 1) accuracy and 2) dynamics.
Acurate speakers (flat frequency response both on-axis and off-axis) will be able to reproduce all the sounds and instruments faithfully. They are extremely clear in the midrange, and smooth in the treble. They have great imaging and soundstage.
At the same time, you want speakers that can play at louder volume without distorting significantly. This will depend on room size. And budget.:D
Bigger speakers that are both super Accurate and super Dynamic will cost you a pretty penny.
But they don't have to be tower speakers like the Salon2 or KEF 207/2. They could be larger bookshelf speakers (stand-mounted speakers).
tulax13me
Biased recommendation but I would try to listen to some Polk LSi's. I absolutely love my LSi15's. They are notoriously hard to drive, however, and would require something on the order of an XPA-5 to get the most out of them. Should be right on your budget of $2k main $500 center, and if you look around can be found for less on Ebay, Audiogon, or Club Polk. For smaller form factor, the LSi9's are also very highly regarded.
I have not listened to many more expensive speakers, but I expect I would hit diminishing returns VERY quickly.
I think the Salk's are often compared with the LSi15's but I have not heard them. Might also throw Axiom M80's and the new Goldenear Triton Two's into the mix.
My use is pretty similar to you--mostly 2 ch music delivered wirelessly with some movies/TV. I would spend the bulk of your budget on the front mains--speakers impact sound quality more than anything else.
My setup (in an apartment):
Front: LSi15
Center: LSiC
Sub: SVS PC 20-39
Pre/Pro: Marantz SR5005
Amp: Marantz MM9000
BD: Pioneer BDP-320
Digital: Apple TV (Gen 2)
For a processor, it's tough to go wrong with the UMC considering the price point. Used you could also look at something like an Integra DTC 9.8, or even an Anthem AVM 30 if you don't care about HDMI and just want the best audio. If you're going with an external amp and are more concerned with audio quality than video you can look at any number of less expensive receivers to use as a Pre/Pro (giving up high power and video processing that drive receiver prices up). I picked the SR5005 over the 7005 b/c I didn't need any of the extra features (although I do love the design). You could also look at the Yamaha Aventage series--they put a big emphasis on audio quality.
You can get a sense how Audioholics would divide the budget based on their recommended systems--search for System Buying Guides--the $5000 Audio System and $3500 Balanced should be in the right ballpark. (Sorry it won't let me post links)
For video (and CD's should you find one), I think the Oppo BDP 83 is a no brainer (if they were $325 when I bought my BD I would have gotten one instead). Best I can tell the 93 only adds 3D and some networking that don't matter. The BDP 80 is cheaper if you play only BD's and don't need the 83's upscaling (also a slight step down on analog SQ).
I use Itunes and an Apple TV to get music to my system and I think it sounds great (used to use an Airport Express with the same results). I've tested blind vs. CD and I can't tell the difference. I have the permanent fiddling bug and have been trying to find upgrades but have yet to find a DAC that sounds different from my Marantz (the V-DAC sounded the same, may try an XDA sometime).
Basically, for $5k you should be able to get a pretty great system--key is finding the mains that you love.
tulax13me
Slerch--great post but I have to correct one thing: the UMC can't drive speakers to any level--it doesn't have an amp.
I would also say that the necessity of an external amp depends on the speakers. I started with a Yamaha RX-V1400 (beefy 110W/ch) driving my LSi15's and the difference when I added an external amp (even if only rated at ~150W) was huge. Not just in volume (which I don't really care about) but in clarity and control. Difficult to describe, but the difference was obvious and I won't be going back.
slerch666
Ah, my mistake. Thought the UMC was a full receiver. My mistake. So yeah, I guess the amp would be needed for it.
Thanks!
Davemcc
Davemcc
Start with this.
or, for less cost
Add this.
Done.
If my house burned down and I had to start over, this is what I would do.
ryandaws
Wow, outstanding responses, thanks everyone! This has been hugely helpful. The Salks weren't even on my radar, but after reading all of the reviews (thanks Swerd) I'm quite interested. Is there any way to audition it before buying or should I just do it?
With a Denon AVR4310, Salk SongTowers, SongCenter, NHT Superzero 2.0, and keeping my sub (which is actually quite good), we're looking at ~$3200. Throw in cables and stands for the center/surrounds and we're probably near $3600. Might use the budget headroom for some of the amazing woodworking upgrades on the Salks; some of those photos are stunning, especially the one-piece baffle with the burled veneer.
From what's been suggested, it sounds like the recommended equipment is an exceptional value. Equipment-wise, what would I gain by using the rest of the budget? For example, I'd had my eye on the Marantz SR7005 ($1600) receiver; is it worth the extra $600 over the Denon? Should I get the SongSurrounds over the NHT SuperZeros? Slerch suggested the B&W's (presumably the CM series, maybe a pair of CM8s + CM Center), which would get me near that level. Is that a worthwhile investment or should I just pocket the difference between the recommendation and the budget, which I'm happy to do?
Thanks again for the help, your responses have been revelatory for a n00b like me!
tulax13me
Unless the SR7005 has features you want that the Denon doesn't I don't think it's worth $600 extra--I really doubt you'd notice any sound quality differences between the two.
With the extra budget I would either expand the speaker budget and search options or save the difference for further tweaking/upgrading in the future (amp? DAC?).
Swerd
Swerd
There is a forum dedicated to Salk speakers on audiocircles. In it is an Owners Audition List. Check there to find an owner near you, or you can post a request there. You can also email Jim Salk directly. If you are near Gaithersburg, MD, you are welcome to come hear mine.
My STs are the standard curly cherry veneer, and they are easily the best looking furniture I own. The custom veneers are a whole step up from that, if you are willing to pay for it. Jim Salk is an expert on choosing stain colors and matching furniture you may already own.
The SongSurrounds are excellent bookshelf speakers by themselves. I personally think they are an expensive choice for rear channel speakers if you listen to music mainly in 2-channel, and movies in 5-channel. Because you originally said that less expensive rear channel speakers could be substituted to keep price down, I chose the NHTs. I have a pair of the original SuperZeros from 11 years ago. They are fine for movies, and not bad at all for music. They are small sealed cabinets that I easily hung on the wall.
I can't really answer your question about the Marantz SR7005 for certain. It might be a bit better, but I'd guess its probably not worth the extra $600.
slerch666
I LOVE my B&Ws, but in all honesty I'd say the recommended setup from others will be as good or better than even going with the CM series for your use.
I would, however, still recommend you try and find a place that has the B&Ws (and similar sized speakers w/ specs and so on) in stock. You won't find anywhere with the Salks obviously, but I'd still recommend, highly, auditioning options if for no other reason to be really happy with what you end up with. And as Swerd mentioned, perhaps try to find someone "close" to you to see if you can audition the Salks in a home. That would be awesome because it would be in a place where it's actually in use and not just the hi-fi shop's showroom.
sholling
sholling
If you look on the Salk Sound website you'll find a forum link. In the forum you'll see the "Owners Audition List" which are Salk customers that are willing to open their homes to allow others to hear their Salks in action.
If you can afford Salk Surrounds then I'd step up from the NHTs and go Salk all around but it's really an unnecessary luxury unless you get into 5 channel music.
zieglj01
zieglj01
Cut back on the receiver cost - in an apartment, you can also
compromise on the surounds - I would get a better sub for the
Salk speakers.
And I would think about droping your surrounds - if needed, to
buy a Salk center channel. Save up for the surrounds later.
...had my eye on the Marantz SR7005 ($1600) receiver; is it worth the extra $600 over the Denon?
...Should I get the SongSurrounds over the NHT SuperZeros?
...Slerch suggested the B&W's (presumably the CM series, maybe a pair of CM8s + CM Center), which would get me near that level. Is that a worthwhile investment...
1) SR7005 vs Denon 4310?
If anything, I would say the Denon 4310 is a better built, better quality unit than the SR7005. The SR7005 did not measure all that great on Home Theater Magazine.
So IMO, the SR7005 is worth $00 more than the AVR-4310.
2) For aesthetics sake, I would get all speakers of the same brand. If you decide on Salk, then get all Salk speakers.
3) Personally, based on my auditions of 3 B&W speakers (800D, 802D, 803D), I think B&W is way overpriced vs sound quality. It's probably just me. After my auditions, I could not figure out why the heck. But some of the good folks here pointed out to me that the very expensive B&W 802D had a worse off-axis response than the cheap Infinity P360 speakers!:eek: Again, that's just me and my big mouth.:D
Electronics are easy to me. Get something with great FR, THD, SNR, Crosstalk, and Power Output. The biggest difference will be Features and Room Corrections - if you use those things.
Speakers are a different story. You ask 100 guys, you get 100 opinions on which speakers are better. The only safe thing is to audition for yourself at a local store.
The next best thing is to buy based solely on reviews and opinions, but from a company that offers a 30-day in-home trial. With the exception of Aperion Audio, which offers free shipping both ways on the home trial, most companies may require that you pay for the shipping both ways. I'm not sure if EMP (own by RBH Sound) pays the shipping both ways or not.
One question you already asked is whether to buy floor-standing speakers vs stand-mounted speakers.
Just keep in mind that regardless of which type you buy, most experts will recommend that you set your AVR Speaker Configuration to SMALL speakers with a Crossover of 80Hz (or higher for smaller bookshelf). Even if your tower speakers are 46" high, 13" wide, and 15" deep. In this budget, practically no tower speaker will be able to play flat (-3dB) from 20Hz - 20kHz @ 90dBA from 2 meters away in an "average size" room. You will want a subwoofer.:D
GranteedEV
GranteedEV
Revel F12 Towers
Revel C12 Center
JBL LSR 2325P Surrounds
Marantz SR5005 receiver from accessories4less for ~$500
and then the rest of your budget on SUBS :D The one infinity might be good, but you still need three to get good in-room bass.
Honestly, you don't need separates with such a mediocre budget. It's a bad place to place your money. Get a receiver and spend on speakers and subs.
