A difference? It's possible that the tube unit is designed to produce substantial even order distortion, and it's possible that it has a poor RIAA EQ tolerance - thus causing frequency response deviation(s).
A Creek OB-15 should make a good transparent solid state pre amp. It has dual modes, too, so you can use MM or MC cartridges. At about $140, it should be in your budget.
-Chris
