looking for reciever 7.1 with extra 2 channels
cronick
Hello,
I am new here, hope i can get some help. I'm setting up a home theater in my basement. I have 7 in wall speakers and 1 sub. Things were going pretty good and then we decided to add a bar to our new project. So what i would like to do is have 1 reciever that i can watch tv and use my 7.1 surround sound, however if the tv isn't on that i can shut off the surround 7.1 and switch to my other 2 stereo speakers by my bar. Do they make a reciever like this? If so what am i looking for. Thanks in advance
mayho
Most new receivers have multipile zone options. This should suit your needs.
MDS
The Zone 2 feature is what you need but you'll have to also get an extra amp unless you want to go into the setup menus of the receiver and re-assign the rear amps from 7.1 to Zone 2 every time you want to listen in stereo at the bar.
markw
Many receivers offer the option of running a second set of stereo speakers. this shouldn't be too hard to find. Look for a speaker A/Speaker B selction on the front.
W
WeAreSurrounded
Try Denon 4306 !
cronick said:
Hello,
There are many solutions here, I'll offer 3:
Most of the medium-level receivers (like mine - Denon 4306) offer 7.1 with amplified ZONE2 (sometimes also ZONE3) :
1) You can use amplified, independent ZONE2 (bar speakers), connected to the Surround Back/ZONE 2 terminals, but then your Main Zone would be reduced to 5.1 :mad:
2) You can use amplified ZONE2, interchanging your ZONE2 cables with SB cables (when not in use), but then you would need to adjust the 4306 setup each time :(
3) You can use non-amplified PRE-OUT ZONE2 terminals, connect them with RCA cables to external amplifier, which would drive your ZONE2 speakers.
That would make your ZONEs completely independent and it's definitely the best solution :p
On the other, you can buy some really expensive (around $5K), high-end 9.1 receiver,with ZONEs (like Denon 5805 series), which would address all your needs :D :D :D
jcPanny
jcPanny
Receiver features
My $300 Yamaha receiver has A and B speaker terminals. If you don't need to listen to the bar at the same time as the 7.1 HT, this would work for your application. If you want 9 speakers at once, you could hook up an inexpensive AudioSource, Behringer, or Emotiva amp to the tape or zone 2 output of any receiver to power the bar speakers.
As suggested above, some of the new $2k receivers have nifty features to simplify the switching process. The new Yamaha RX-V2700, for example, will change from 7.1 to 5.1 + powered Zone 2 when you turn on the Zone 2 speakers with the remote.
