A/V Receiver / DVD / CD player combo?
I've never looked into home theatre before, really because I've never felt the need, but recently I realised that when I go to University in October I'd like to have an all-in-one system that can do all the stuff I want with the minimal amount of hassle.
To that end, I'd like to know how it is possible to achieve the following setup:
I'd like an A/V receiver, with an AMP, as well as a DVD/CD player. So this thing would input/output signals from various audio and video sources, as well as playing DVDs and CDs.
Second, I would like my computer to input both sound and video into this receiver.
Finally, I'd like a television hooked up to the receiver that takes the audio and video from DVDs, as well as the video from the PC so that it can be used as a second monitor. I'd like the audio from CDs to play only through the speakers though.
Point to note: I'm NOT an audiophile. I only want 2.1 sound at the most, mainly because I don't care to have more speakers than are necessary, because I like simplicity, and because I won't have lots of room to put this stuff. I don't need fantastic sound quality either, because I really can't tell the difference, and don't care to try. I was ideally looking to hook all of this up for under £500, which should be possible given my lack of need for a high quality system.
Thanks in advance for all the help. Any suggestions you guys can make will be really helpful.
