Looking for good multiroom/source for Paradigm speakers
drinke
Currently I have Monitor 7s and a C290. My dealer allows me to upgrade every year (substracting out the cost of the prior years speakers), plus I can get a 20% discount. This year I think I might jump to a 390 and either the 9s of the 11s. But the following year - cash flow permitting - I'd like to jump to the studio line C 690 and either the Studion 60s (most likely) or the 100s.
The sub is a paradigm sub, not great - will eventually go with SVS I think.
Overall the speaker upgrades will take the next two years.
But my present receiver ain't so good - its an older yammy HTR model.
I'd like something with solid sound and some of the newer video processing capabilities. But multizone/multisource is key, I need 2 zones, both powered from the receiver. I do not play loud - have young kids and the monitors take almost no power to drive them anyway - they are very sensitive.
I am looking at the Onkyo 805, the Yammy 1800, Denon 2808ci and perhaps the Sherwood 872. All are at, or slightly north of 1000 (though I probably won't buy until after the new year - looking for sales, possibly).
I am not opposed to separates either, but my currenty year budget for a receiver is 600 - 1000. So, if the feedback is that I should get a lower end receiver now (assuming I do not lose audio quality) and then add an amp later, I'd like to thoughts on that as well (though I think I lose multizone capabilities with a lower end receiver).
Basically I would like a good short term solution that I can build on as my needs/system grows.
If it helps at all, my video source is a crappy Samsung DVD player (to be upgraded when the war is officially declared tie) and a crappy motorola cable box. But these feed a Sammy plasma.
jcPanny
jcPanny
Receiver options
Drinke,
I have a lower end Yamaha receiver and Added an Emotiva LPA-1 amp to power my 4 ohm Onix Ref 1's and Ref 100 speakers. Two channels of the amp are also used to power my distributed audio system. An outboard amp is a good option for 4 ohm speakers like the Paradigm Studio and a Zone 2 system with more than 2 speakers. Also, I think that upgrading to the Studio 20's now would be a better performance improvement than newer Monitor series floorstanders.
You only need a receiver with 2 or more zones if you want the zone speakers to be playing a different source than the main HT. Some of the new Yamaha receivers are very flexible in that they allow you to have a 7.1 HT w/ zone speakers off and a 3.1 (or 5.1) HT with powered Zone2 and/or Zone3.
drinke
Thanks much -
I've actually toyed with the idea of upgrading to studio 40s since the price difference between them and the 11s aren't far off - but my problem was the price difference between the the c290 (which I have now) and the C690 - then I was worried that my center might overpower the 40s (which might mean jumping to the 60s or 100s this year) - that was starting to look expensive -
The dealer 1 year upgrade feature requires that the upgrade be at least 50% more in price than the lower grade speaker being upgrade. This makes for some tricking planning re: upgrades, especially if I want to go from a 590 to a 690 - but that's what might happen.
Anyway - tha
