looking for cheap pro amps
markkirk1
I was wonder if any of these amps are good
BRAND NEW TECHNICAL PRO DA-B3000 3,000 WATT CLASS "D" FULLY DIGITAL CIRCUITRY 1U RACK MOUNT PROFESSIONAL DJ POWER AMPLIFIER
DA-B3000 Professional Digital Amplifier
(2) Free XLR (Female) to RCA (Female) adapters included!
(2) Free XLR (Male) to RCA (Female) adapters included!
Digital circuitry keeps amp cool while providing perfect sound reproduction
3000 watts peak power
2 x 550 watts @ 6 ohms
2 x 300 watts @ 8 ohms
Inputs: Balanced XLR + RCA inputs with included adaptors
Outputs: XLR (passive), and Original Neutrik Speakon outputs (active)
Ultra Light weight amplifier
Class "D" with No transformer (This means the amp will not overheat like conventional A/B power supplies)
Iridescent blue LED meter signals and clip indicators to monitor performance
Clipping indicator per channel
110/220 Volts compatible
19" Rack Mountable
Channel Volume Controls
“CAF” (Complete Air Flow) ventilation system including air filter with automatic variable-speed fan for smooth and quiet operation
Bridgeable
THD: Less Than 0.1%
1U Rack mount
Class "D" fully digital circuitry! These will never overheat on you or start clipping like conventional class "A/B" amps
High-quality components
Exceptionally rugged construction makes this perfect for mobile DJ's and Fixed Installations
GEM SOUND EXA-2955 2,000 WATT 2 CHANNEL RACK MOUNT STEREO POWER AMPLIFIER WITH BUILT IN FAN, 1000 RMS WATTS, AND FRONT OUTPUT LEVEL METERS
Features:
2000 watts peak output
500W @ 4 Ohms bridged
350W @ 4 Ohms
250W @ 8 Ohms
Left and Right channel Level controls
Ground Lift
Protect LED
Peak LED
Fan Cooled
Inputs: 1/4" Input and Balanced XLR and RCA
Outputs: Banana Binding Post & Speaker on
Rack mountable
Dimensions: 19" W x 5.25" H x 17.5" D
110/220 volt switchable
Any input would helpful will be powering paradigm studio 100s v.5 and cc690 v.5 thanks
markkirk1
If went with the Behringer amps what do I to hook them up to a yamaha RX-V 1700 receiver as far as adaptors
Thanks
markkirk1
can I use banna plugs hook speakers to this or do I need adptor for that too
Soory for all the question but I want to get everything I will need to get amps running with as few problems as possible also where would get the fans for the fan mod
Thanks
ParadigmDawg
ParadigmDawg
Yes, you can use banana plugs.
I can't remember where I ordered the fan but the mod was simple. Search around on here and you will fine the fan thread (I will look too). I want to say it cost me about 8 bucks online.
tcarcio
Just so you know if your reciever doesn't have an output voltage of 1.4v then you will not get full power out of the amp. If it does not then you will need to use a line leveler such as an Art cleanbox or a Rolls mb15 to balance the input voltage to the amp.
markkirk1
which would the ARTDTI or the cleanbox that is powered with 12 volt transformer Im sure I will need them and also let me send a balanced signal to my paradigm sub 12 in the future
thanks
ParadigmDawg
ParadigmDawg
The "powered" one will send a frequency attenuation to the amp (not what you want).
Get the DTI.
markkirk1
Ok thanks for all of your help I will get artdti then thanks again
markkirk1
d0rkiishchris
used crowns
the company i work for has a couple dozen pro crown amps they are getting rid of. The thread title said u were after pro stuff and cheap. If you search crown com-tech 410 on ebay you'll probably find it.
markkirk1
I will look in to it thanks for the tip
Markkirk1
