Looking for bookshelf speakers to replace my FPM4s...
niallsmart
niallsmart
Guys –
I'm looking for some advice on bookshelf speakers to replace my B&W FPM4s. I originally bought them for a HT setup, but no longer own a TV (yes!) so I'm only using them for music now. I don't have a sub and the complete lack of bottom end is really getting to me.
The amp is a NAD L75/L55. The room is pretty small and oblong (about 20' x 10') and the sofa/speakers are placed opposite to each other along the shortest dimension.
I'm looking for a pair of bookshelf speakers that:
  • Are flexible on placement (I'll need to place them close to or right against the wall so presumably that means sealed or front-ported design?)
  • Are alive at low volumes.
  • Cost less than $1,000 pair.
  • Look good.
So far I've looked at the NHT Classic Three/Two (I'm happy to upgrade the amp if needed for a sealed box design)
Any other suggestions to check out?
Niall
niallsmart
niallsmart
PS - you can see some photos at bit(dot)ly/d5w5fZ (sorry, I can't include the link directly as this is my 1st post)
GranteedEV
GranteedEV
Why not just keep the B&Ws and get a sub for them?
A Rythmik F12 for example? It'll bring the low end on your music to life much more than any sub-1000 bookshelf can.
But, since I already linked ascend acoustics, I might as well recommend their Sierra-1.
Matt34
Matt34
Moderator
niallsmart
niallsmart
Thanks for the feedback guys.
Will the Sierra-1's work well in that position? I don't have a whole lot of room, so they would have to be placed around 4" away from the back wall –*I thought this wasn't enough distance for a rear-ported speaker...
