Glad to see you're still around
@Timothy E Smith !!!
Didn't you just buy a receiver? Have you tried running the auto set up?
If I recall, you had some placement issues. Have they been addressed?
Otherwise, given your rooms limitations, you will only be paying someone to run the receiver's set up program for you. There's not much that can be done without buying furniture/stands/mounts that put the speakers at ear level.
