looking for a wall mounted audio rack
gweedo
gweedo
I can't seem to find any wall mount audio racks? I need a 4 shelve rack that will mount a wall and hold at least 20-25lb's per shelf.. Only one close I can is a peerless however the weight rating is low to hold my stuff.. Also this is for a in view rack system, I'm buying a house and barely have room for the tv and towers so I wanted to go up the wall to put the components.. Any help would be great..
Thanks..
gweedo
gweedo
thats what i am looking for, however I don't have another room to put all that stuff in.. Was hoping to find one that would look good enough (and not cost my first born) to put above one of my towers facing the couch..
E
Exit
We just got out of a meeting and the presenter had about a four foot high A/V rack with a glass door and mounted on casters. If you took the casters off it might be close to what you are looking for. I would google "audio racks" and there should be a lot of companies to look at. The rack I saw might have been bought through some business channel versus consumer channels. You could also have one custom made by a cabinet maker and it may not be that expensive.
jcPanny
jcPanny
HT Shelves.
Similar brackets with tempered glass shelves would look pretty good. Your local class place can cut the glass to any dimension and bevel the edges. I paid $100 for 4 tempered glass shelves for the entertainment center I built.
Another Option would be to install the gear in a closet and use an RF remote to control the equipment.
gweedo
gweedo
how does the ventalation work when its in a closet? I plan on having a 3808CI but have a avr-1600 for now.. OH and I realized that the 3808 is almost what 45#'s, so I need a heavy duty wall mount or I will need to get creative.. Close on my house May 9th..
Thanks guys..
