looking for a projector for outdoor use
L
LOUMFSG
I've recently upgraded the home theater system with a Denon AVR-4308 and a Samsung Blu-Ray player. This receiver supports two hdmi-outs from zone 1, and component video out for zone 2. I've run both hdmi and component cables out to the end of a built-in counter out on the patio, where I could hook up projector to show movies at night. I plan on using a portable screen, which will be stored inside with the projector when not in use. The house is about 18' from the counter where the projector will sit, so I am thinking the screen will be about 16'-17' from the projector.
I know very little about projectors, and was hoping to get some tips. Since I'll have a Blu-Ray player, I was thinking 1080p is the way to go. I assume since I'll be showing outdoors, getting a bright projector is important (what is considered good brightness for outdoor viewing at night - would 1,800 AL be sufficient?). Given the trade-off between brightness and contrast ratio, should I be looking for a brighter unit, or one with higher contrast ratio? Given the distance between the screen and projector, what throw ratio should I be looking for.
BenQ looks like they have a new unit coming out soon (the W-1000), which is 1080p, 1,800 AL, and a 2,700:1 contrast ratio, for about $1k - looks like a good deal. Would this be a good value for what I am planning on doing?
Also, I know even less about screens. What should I be looking for in a screen? If I'm going to be spending about $1k-$2k on a projector, how much should I plan on spending on a screen? What screen surface should I be looking for, and gain, again to optomize for outdoor use at night.
Any advice you can give (or is there a link to a good buying guide that you would recommend) would be greatly appreciated. Thanks in advance.
BMXTRIX
BMXTRIX
You want to read reviews of projectors from this site, Projector Reviews, and Projector Central before you buy anything. It's important to understand that MAX rated lumens is rarely true of real world lumens, and is typically at least off by a factor of two.
But, if you have a nearly 100% dark environment - no outdoor lights shining on the screen, then you should be able to get away with near THX standards of about 14-17 lumens per square foot of screen size.
For a typical home theater screen in the 92" to 120" diagonal range, that's about 400-600 lumens without issue at all.
Yet, at a 15' diagonal, you will want to ensure that the real world deliverable lumens can really do what is promised. The Epson 6500UB for example can deliver over 2,000 ACTUAL lumens, according to testing, even though it is rated for less than that.
