Hi All
I have a great deal on a very nice front projection system I am bundeling it together with 45"x80" Electric Screen's with IR remote control system
this is the top of the line Home Series screen (not the cheap ones)
Hitachi PJTX 100 1280x720 Home Theater projector
These are both new in factory sealed boxes
Retail on the projector alone is $3900 I am selling the set for $3500
Limited to stock on hand
Overview
Hitachi’s new PJTX100 High Definition Front Projector provides a large screen size solution with flexible installation options and unparalleled image quality. The 3 Panel 720P LCD light engine and exclusive Super Focus Quattro ELD can create an image from 30 to 300 inches, with incredible clarity and brightness.
The Super Focus Quattro ELD lens system includes lens shift capability as well as 1.6x zoom functionality. The lens shift feature in the PJTX100 allows the unit to be placed off axis from the center of the screen without having to use digital correction. The lens system itself shifts the image both vertically and horizontally, maintaining detail and sharpness.
A host of picture adjustment features allow the PJTX100 to be properly calibrated for any home theater environment or incoming source signal. Black levels are extremely important to the picture quality in a Front Projector, 10-step Motorized Iris control, 3 Optical Black Level settings and an exclusive 8-step Gamma adjustment feature ensure optimal picture quality for any home theater display.
High Definition Capability:
The PJTX100 utilizes true 16:9 3-Panel 720P LCD light engine and an exclusive Super Focus Quattro ELD lens system to reproduce High Definition images with incredible clarity
Installation Flexibility:
Optical lens shift, both vertical and horizontal, allows the PJTX100 to be placed off axis from screen center, but uses lens shift to center the picture on the screen not digital correction which degrades picture quality. A 1.6x zoom lens also allows the unit to be positioned at various distances from the screen, as close as 9’2” or as far as 15’ from a 100” screen
Exclusive 8-step Gamma Curve Adjustment:
Black levels are critical to any television picture, but especially so for Front Projector displays. The 8-Step gamma adjustment allows for adjustment of specific grey scale values without effecting the overall contrast. A gamma fine tuning feature is needed to obtain the best image for any screen type and viewing environment.
5 Preset Picture Modes and 4 Memory Modes:
For ease of use in any environment 5 Preset Picture Modes create global changes to several key picture adjustments to suit varied environments and source material. If detailed calibration or adjustment is applied, 4 memory modes can be saved for specific viewing needs.
Backlit Remote Control and Easy Menu System:
An ergonomic backlit remote control allows for one button access to the most commonly used features. The motorized 10-step Iris control works directly from the remote. An Easy Menu is available for simplified operation after initial setup is completed.
RS-232C Interface:
Allows for the projector to be incorporated into system control for advanced designs. Incorporate the PJTX100 into an operating system which can control all aspects of the home theater environment including room lighting, picture settings, as well as motorized screen and ceiling mount options.
Additional Specifications:
Key Features:
– 1280 x 720 Resolution
– HD 3-Panel Light Engine
– Exclusive Super-Focus Quattro ED
Glass Lens with 1.6 Zoom
– Horizontal and Vertical Lens Shift
– Motorized Iris for High Contrast
– 1200:1 Contrast Ratio (Iris On)
– 1200 ANSI Lumen Light Output
– Motion-Adaptive Progressive Scan
– 3:2 Film Processing
Convenience Features:
– Illuminated Remote Control
– 5 Picture Preset Modes
– 4 Customizable Picture
Memory Modes
– Lens Shift and 1.6x Zoom for
Flexible Installation
– Whisper Quiet 25db Operation
with Front Exhaust
– VGA-UXGA Input Compatible
– Projection Sizes:
Up to a 300” Screen Size
60" 16:9: 5' 7" - 8' 10"
Throw Distance (1.7m - 2.7m)
80" 16:9: 7' - 11' 10"
Throw Distance (2.2m - 3.6m)
100" 16:9: 9' 2" - 14' 9"
Throw Distance (2.8m - 4.5m)
Inputs/Outputs
– DVI-HDTV Input: 1
– D-Sub 15 RGB Input: 1
– Wideband Component Video: 1
– S-Video Input: 1
– Composite Video Input: 1
– RS-232C Control Interface: 1
Specifications
– Resolution: 1280 x 720
– Consumer Replaceable
Lamp: 150 Watt UHP
Dimensions
– Height: 5 9/16"
– Width: 13 7/16"
– Depth: 11 1/16"
– Weight: 9 lbs.
SCREEN DETAILS
http://www.elitescreens.com/productshome.html
