Looking for a bracket to connect Polk Audio SurroundBar to a Plasma
soccerwf
Does anyone have suggestions on how to mount a Polk Audio SurroundBar to the bottom of a plasma? The plasma is on a cantilever wall mount and I want the SurroundBar to "follow" the plasma as the plasma is moved to various viewing angles.
Thanks,
Will
O
owasse
Since none of the professional installers chimed in, I'll try and help. While I'm not too familiar with your soundbar, I noticed that Crutchfield does have a mount for the polk soundbar which you might be able to adapt and connect to the display's wall bracket. Hope this helps and if nothing more, gets you thinking of alternate ways to adapt a bracket. Best of luck!
It isn't designed to move, as the effect of the surround is based on where it is positioned, so proper placement within the room is actually going to be fairly important. Based on that, I wouldn't mount it where the placement was flexible. Just my $.02
