Looking at used PSB 500 speaker pair..rust mounting screws.
3db
3db
Some of the screws are rusted around the woofer as shown in the pic. I will replace them of course but is this indicative of another bigger problem? These will be used as spares in case I run into issues with the existing pair.
John Parks
John Parks
Nice!
Um, were they kept outside? How did they rust?
KEW
KEW
Wondering if these spent time at the coast where the salt would accelerate corrosion. Especially in a sunroom where the windows would often be open.
Also, usually a company uses the same hardware (or at least the same coating on the hardware) for all of the mounting screws. What differences do you see? It looks like some of the woofer screws were not rusted?
slipperybidness
slipperybidness
Yeah, I'm thinking on the coast or garage duty.
I would just have to consider the price and go from there.
zieglj01
zieglj01
A lot of times it is just the screws (cheap ones), replace them -- sometimes I just paint over them -- you may want to paint over the inner screws that hold the tweeter to the faceplate
3db
3db
I picked them up last night for $90 after listening to them. They sounded good and the rust on the the screws were not nearly as bad as the pics made it out to be. The grills are in better shape than my current ones which I have swapped to the active pair.
John Parks
John Parks
Nice find! Glad the rust was not too deep...
