Looking at buying Paradigm Studio 100's v.4 or Studio 60's V.5? New to home audio, p
K
kiwanoron
I am new to this site.
I have an Integra 8.9 receiver. I am looking at the cc-690 for the center channel. I will use the system for 40% 2 channel music and 50% HT. I can get the Studio 100's v.4 for $1900 and the 60's v.5 for $1700. I am not sure what direction to go in? Any advice will help. I only have a background in high end car audio.
I plan on running at least one powered sub, maybe two? Someday I may buy a separate processor and amp but not in the near future(at least a year out).
jamie2112
What about the other 10% ????:D I like the 100's much better.2 subs are always better than 1 IMO.....
K
kiwanoron
jamie2112,
The other 10% I will just look at them and enjoy:)!
It should have read 40% 2 channel stereo and 60% HT.
Have you heard the 60's v.5 or the 100's v.4? I have not heard any of them at this point. I can not listen to them side by side since the 100's are 3 hours west and the 60's are 2 hours east of here.
Chopin_Guy
Chopin_Guy
Kiwanoron,
I listened to the V.5 Studio 60's just a few weeks ago and liked them very much...and of course the new look / cabinet design is quite nice as well. They have a nice detail and focus to their sound, without being to bright, and a wide sound-stage. Not that words can get at all of what one hears, but that is the generally impression I got without doing alot more and varied listening to the speakers.
As for the 60's over the 100's I think that really depends on the room size, your listening habbits (i.e. how loud do you like it?), and your subwoofer. In my case I know that the 60's would be plenty with a PB13, but in a larger room with higher listening levels the 100's would be desirable. This comes down more to personal preference....
Either way you will be most happy with these speakers...
jamie2112
Cuz why??
I have only heard the 60s.
The 100's are alot louder and bigger sounding(of couse)......I have not heard the 60's but I am sure I know I like the 100's.Thats not to say I don't like the 60's.....I just prefer larger speakers.....
ayrton
Get the 100s and the 690 and never look back.
I have 100s V4 and a 590 and want no more. Using a Onkyo 906 Bi-amping the 100s. Very Dynamic!! :D
K
kiwanoron
ayrton - I was also planing on bi-amping the front speakers, just was not sure how hard it would be on the receiver (integra 8.9)?
Does it matter how far the speakers are from the wall? I was planing on only keeping them 2 or 3 inches away from the wall. I just read something that said they should be moved away from the wall?
K
kiwanoron
I meant bridging the front speakers with the Integra 8.9 not bi-amping them, since I am only running a 5.1 system...In the Integra manual it says only bridge speakers with 8 ohms or higher. What are the paradigms rated at? On the paradigm website it says compatible with 8 ohms?
F
fredk
Thanks Jamie. I thought maybe you had listened to both. I went through something similar when I bought my system, but I was lucky enough to be able to compare the two models I looked at side by side.
kiwanoron. I am willing to bet that there are differences between the two models, but that they are subtle. That is what I noticed in my case.
K
kiwanoron
Setup advice???
Any suggestions on Integra 8.9 setup?
I have an Integra 8.9 receiver. Paradigm Studio 60's v.5(thank you all for your suggestions) and a cc-590 v.4(planing on buying a cc-690 v.5 in the next two months). I have two Monster THX SL200-SW Subs, I paid $600 for both of them with a 5 year warranty, I know they are not the best but could not pass on the deal. I have to wait two weeks for the rear ADP speakers. I am planing on running a 5.1 system.
Here is where I could use some help:
-The integra has an option for bridging the front channel - is this a good idea?
-I also read about bi-amping the front speakers? - Not sure what is the best way to go since this is my first home system what is not a HT in a box!
- For the Subs I ran the Sub preout to one sub then out of that sub into the other(as it said in the directions)
In the Integra setup for the speaker configuration what should I set the settings at for the
-Front Speakers(paradigm Studio 60's V.5)
-Center(Paradigm cc-590 v.4)
-Sub -LPF of LFE (2 Monster THX SL200-SW Subs)
-Rears (Paradigm ADP not sure what one, most likly studio)
If you have any other suggestions Please let me know.
THANKS ~ RON
K
kiwanoron
For Integra setup for the speaker configuration what should I set the crossover settings at for the speakers, all 80 Hz? Do I set this first or run the Audyssey first, will it set the crossover points for me? I have never done this so not sure where to begin?
-Front Speakers(paradigm Studio 60's V.5) Crossover?
-Center(Paradigm cc-590 v.4) Crossover?
-Sub -LPF of LFE (2 Monster THX SL200-SW Subs) Crossover?
-Rears (Paradigm ADP not sure what one, most likely studio) Crossover?
AVRat
AVRat
Don't bother with bridging/bi-amping. 80 Hz all around. LFE input on the subs.
Harrison476
I have the onkyo 875. I have tried both bi-amping and bridging the fronts – surround backs. In my opinion neither is worth it. The bridging option really limits your receiver’s options. This is especially true if you want to listen to HT movies. I would do this only if I wanted to listen to 2.1 channel music (still you lose some of the receiver’s options). I could not hear any sound benefits from the bi-amp option. I did use it once to run two sets of fronts. Bi-amping does leave you with 5.1 channel (no 7.1) but I believe you still lose some of the available listening modes.
At the end of the day I could not hear any improvement in sound from either option.
F
fredk
Since the receiver has only one power supply, that is the limiting factor. You gain nothing by either method.
ParadigmDawg
ParadigmDawg
100's all the way. They like power so plan on an outboard amp in the future unless your room is small or you listen softly.
