davidmore said:
I have now had an AE 900 for about 4 months - and am considering what my next upgrade step should be.
Environment is a Marantz DV-9600, Yamaha 2600 AVR and the Panny - connected via HDMI. Also have an Aussie HD tuner and our SD Cable Service.
My room - sadly is oddly shaped with white walls and ceiling - so there is some reflection back onto the screen. Panny is ceiling mounted. (Getting at that air filter every 100 hours is a pest I must say!)
Light control is only average during day - fine in the evening.
Question is which of the options sounds best. Screen is 100" 1.1 gain.
1. Reduce screen size to 80 inches - more light better contrast?
2. Get a screen with say 0.8 gain - suggestions for Australia welcome or a 1.3 or 1.4 gain
3. Get a new better projector - more light? DLP etc.
All suggestions considered - for comparison I have a Sony 45" CRT RPV which provides blacks etc that blow the Panny away I fear. (Sits behind roll down screen).
What is the sensible next step - $2000-3000 available.
Sound is fine - ProAc EBS Main - Pair of LS35A - as Centre and Warfdale Ceiling monted at rear. ProAcs driven by a 300WPC Yamaha main amp so the other channels have lots of reserve.
Wife finds 100" too big - hence the interest in a possible downsize..but I would like to stay above 80" or so.
Thanks for any and all comments.
David
I am not sure now is the time for you. HD type DVD is just around the corner. I'd save instead. Or, you will be looking for another upgrade in about 2 years.
Light control is a must for projectors. Would not recommend downgrading to a .8 gain screen. And only upgrade to a higher gain if the light on screen, footLambert is almost there, for a theater experience, 16 ftlambert.
Most theaters in the states are less than 16 fL, 12 and some less.
