sublime1
I have one of the IR blasters from SmartHome -- a receptor "eye", a powered box, and a ribbon cable with 6 emitters that you stick on the devices you want to control, plus a green led that lights when a signal is being sent. I have my receiver and TiVo box in a (ventilated) cabinet with wooden doors and the eye located outside the cabinet.
I just got a new AV Receiver set up and relocated components, and now the IR blaster doesn't seem to be working -- I have one emitter attached to my TiVo and one to the receiver. I am pretty sure I have the TiVo emitter located correctly as it is in the same place as it was before I revamped things. I'm less sure about the new receiver (Yamaha HTR-5990) -- I shined a flashlight in the panel, but it is not obvious where the IR receptor is. I did some basic testing by putting a magazine over the panel and am pretty sure I got it pretty close.
So, I think the blaster is not working. If I close the cabinet doors and aim right at the IR "eye", no IR requests are processed, either TiVo or Receiver. Usually when emitters are just mislocated, you get some commands processed.
Any suggestions on how I might test the blaster? It worked before I "fixed" things
Is there a telltale sign that would help me locate the IR receiver inside a component?
Other ideas?
Thanks in advance.
Tom
Other ideas?
Thanks in advance.
Tom
