Locate IP address for Yamaha RX-V471
Audiolux
Hi forumers,
Greeting to all. New member here. Was wondering if anyone could help me located the IP address for the Yamaha RX-V471 as I have googled and still could not find the solution. I need it to use for the iPhone Yamaha AV Controller.
Thank you.
BMXTRIX
BMXTRIX
There is no ethernet connection on this receiver and based upon the price I wouldn't expect wi-fi to be built into it.
If this is the case, then this is not a network enabled device at all. Not sure what you are trying to do, but the only iPod use this receiver has is a USB port to connect your iPod to and play music back on.
Audiolux
BMXTRIX Thank you for you reply. Just called Yamahaand was told that network connection is supported only from the RX-V671 up.
Cheers
