LN40A650 120Hz LAG???
jard7
I just got a Samsung LN40A650. I have a Playstation 3 hooked up via HDMI cable.
I have the Auto Motion Plus 120Hz set at Low. I have tried Medium and High as well. I am noticing some lag in certian scenes and it is kind of annoying. I have been looking online to see if anyone else is having this kind of an issue. From what I can see it is normal. But I would really appreciate it if some one could tell me for sure what the skinny is. Or if there are certain settings I can change to make it go away. I would turn off the setting but what is the point in having that setting if it doesn't work properly. Please help.
bandphan
bandphan
Yes this is known problem with most lcd displays. Try it with it off, which some prefer
