.....Mac and JGarcia, thanks for the responses....and JGarcia, I personally am glad you showed up here and started posting.....
.....guys, I may have some hearing loss, and I'll be the first to admit there were some experiences in the mechanical dept at the railroad before I transferred over that could have been the culprits.....locomotives have pop-off valves on their air reservoirs-sp?, that are SO L0UD, it sounds like it is IN your head when you are close, and they pop-off sometimes for 3-4 seconds.....
....the speakers I have are two-way with 8 inch woofers....now that combination with a button tweeter ain't gonna' have the low end of say a 3-way with 12-15 inch woofer....but what I get from mine mids-up is worth not going for 3-way, I assure you....
.....to add a little oomph to the lower end of the fronts/mains, I am going to try twoooooooo TL's wired in parallel, and let me add, Bob says my want is based on the TL's not being on the floor, but having experienced them imaging at about 57 inches from the floor into my surround space, they will stay, gives a clean brilliance at sitting ear level AND above your ears....makes the room a better filled-up chamber in which to occupy the lower, imo.....
.....I say find the presence-mids-up you want, and then tweek something if need be....listen to perspective speaker purchases with the bass tone controls as low as possible at least part of the time, with the treble tone controls set at what sounded good before you took away the lows...."see how well the mids-up, stand on their own with the lows gone"....but, prepare to hear distortion up high....cranked just decent-crank.....
.....if you have to jack the high tone controls three or four clicks with the bass acceptable, go to the next speaker consideration....or don't, it's your money....
.....I may go to a 15 inch Electro-Voice woofer rated from 60-6000, in a seperate shelf-ported box, cut at about 4500-ceiling with a quality crossover using only the low end of the crossover....I don't know, I suspect the two TL's, side-by-side, up on the sub box, getting hit with 3 ohm watts, and we didn't lose half the damping factor because the amp is not strapped, BREATH, will do the trick....we'll see....used to, you could order the 15 inch woofer from EV for $206 as a replacement speaker with no nomenclature on the woofer, opposed to about $400 with the nomenclature stuck on the back of the magnet....is a small circle of black paper with white lettering worth $194?....don't think so.....
.....Audioholics.com....I appreciate that hobo in the fourth boxcar back telling me about this site, haha.....
