Line conditioner & dedicated outlet?
brad1138
brad1138
Is there any benefit to a line conditioner if you run your system on a dedicated circuit? I installed a dedicated 20 amp outlet with a clean run of 12 gauge Romex about 30 feet long. Is there any point in upgrading my Adcom ACE-515 line conditioner?
Thanks,
Brad
WaynePflughaupt
WaynePflughaupt
Even if you don’t need the line conditioning, the ACE-515 is a great little unit. It gives you a place to plug in all your gear, and the delayed turn-on / turn-off is a great feature if you have outboard power amps.
Regards,
Wayne A. Pflughaupt
dapack69
dapack69
He was asking if he had to upgrade his current unit. That is why I stated no, I agree with what you said about using it. Thats why I use mine.
