The main reasoin for passive radiators is you can have a small enclosure and still keep a low tuning point. With the ever increasing need for WAF friendly speakers, I would be surprised to see many sub-speaker company's using the large ported subwoofers any more(Well, for the married market at least
Obviously there will be those that must have the big ported ones, and serves them right. It's the best way to get good bass, for cheap. Passive radiators have there fallies, including slapping, and still not having that "sealed" sound. I also believe they cannot produce the same amout of SPLs as a ported system(don't quote me on that).
As for servo's, I've heard many opinions, but the one that made me really think about their effectivness came from WmAx.
(Roughly)"A servo is only useful on a poorly designed driver. If the driver is capable of large amounts of linear movement, as well as low power compression and is implemented in a proper enclosure with sufficient amplification, the servo will not be very effective."
I personally agree with this, but I still think a servo is a good way to help a subwoofer out. I would like to see a servo implimented on a good quality driver, and see if there is a big difference.
Sealed subs have that sound. Even a poor quality driver can sound better in a sealed box. Obvisouly they don't play as loud as ported subwoofers, and they also loose low end extension (given the same driver in a box designed right for it's certain application be it ported or sealed. The ported version having the better extension).
But even with that, you can still yield subwoofer from every class that perform well. Velodyne makes very loud, low, and clean sealed subs. I've also seen poor sealed subs. It depends on the measures taken to build the box/drive/amp, and where (if any) the corners were cut.
SheepStar
