I have a marantz 5.1 processor (DP 870) and I am running two powered subs out of the sub out using a Y adaptor. Should I be using the mono input on both subs or left on one and right on the other? Thanks!!
Rick.
Hi Rick,
You can even use both (Left & Right), from the back of each sub, using a Y adaptor there too. You'll gain a little more Gain (Volume level), from your subs.
Absolutely no problem at all doing it that way. Plus, you eliminate any possibility of a small amount of distortion, from the other unused RCA input jack.
That's what I personally do with my two 15" subs, and it works just great.
Cheers,
bob
